drive shaft I think can anyone help
Posted: Fri Dec 10, 2010 9:41 am
by jcozens
Hi all, my van has been making a noise from the rear but only when it is in gear and when I take my foot off the accelerator, if I place it in neutral or if I put the hand brake up a bit the noise goes, it sounds like something is not matching properly like when you used to put a playing card on your bike as a kid thats the best way to describe it. I'm showing my age I know! Any ideas would be great.
Re: drive shaft I think can anyone help
Posted: Sun Dec 12, 2010 3:35 pm
by jcozens
has anyone any help on this ?
Posted: Sun Dec 12, 2010 4:48 pm
by M 80NGO
Is it 2 or 4 wheel drive, petrol or diesel ? have you had a look under the vehicle to see if its anything obvious, is the exhaust rubbing on the rear axel tiebar when people are in the back, also where are you located as there maybe another member who's near you and can have a lill looky for ya :wink:
Posted: Sun Dec 12, 2010 6:21 pm
by MAZABON
does it happen when you are moving or stationary ?,
as you say it stops when you pull the hand brake up a bit, it might be the hand brake cable touching the body/chassis somewhere and rattling and when you pull the hand brake a bit the tension changes in the cable and moves it away a little bit so it stops ?
Posted: Tue Dec 14, 2010 6:12 pm
by jcozens
hi its the 4x4 2.5td 1997 it make the noise when it is in drive when take your foot of the gas it the engine is slowing down thats when it make the noise when I place the hand brack on will driving the noise stops and it will stop if I place it in nutural also when its moving hope tis help I am also in the lincoln area thanks all jamie
Posted: Tue Dec 14, 2010 7:25 pm
by dandywarhol
Broken handbrake shoe inside the rear disc?
Posted: Wed Dec 15, 2010 7:07 am
by dave_aber
Loose rear wheel?
I've had this before - and although the wheels looked tight, and passed the 'shake test', one rear wheel was actually loose when I checked with a torque wrench.
