bob wont start
doobie
bob wont start
Post by doobie » Thu Dec 16, 2010 2:29 pm
well getting fed up know, new battery,new glow plugs and a recon starter motor. it aint got enough jucie(after charging battery)to turn starter motor, any idaes as to where ive gone wrong? :(
Alacrity
Re: bob wont start
Post by Alacrity » Thu Dec 16, 2010 2:31 pm
Poor earth?
wormey
Re: bob wont start
Post by wormey » Thu Dec 16, 2010 3:01 pm
Check the voltage on the rail, if none then it could be the earth from the glow plug relay
Daz and debs
Re: bob wont start
Post by haydn callow » Thu Dec 16, 2010 3:09 pm
wormey wrote:Check the voltage on the rail, if none then it could be the earth from the glow plug relay
If that was so....it should still turn over the engine which it isn't.....check the battery terminals are clean and tight......then check the battery earth cable is tight at the other end.
Failing that.....check the battery voltage is good and nothing is left on when you switch off.
doobie
Re: bob wont start
Post by doobie » Thu Dec 16, 2010 3:25 pm
i think ive found it.....its the valve thingy (you can tell i'm not mechanicaly minded) by the throttle cable............i hope. all electrics are working fine correct readings and all. :)
wormey
Re: bob wont start
Post by wormey » Thu Dec 16, 2010 9:22 pm
Very true, didn;t read that bit, perhaps I'll shut up then. :oops:
Daz and debs
