http://www.maplin.co.uk/Module.aspx?ModuleNo=97788
Thanks in advance
missfixit70 wrote:You'll need to get a small kettle, I got one that's @600w I think, then a suitably sized inverter & you'll need to keep the engine running ideally, or the LB will be flat in no time, that one you've linked to probably won't even run a laptop TBH. It can be done, but it'll be a bloody expensive cuppa unless you use it a lot.
Or get a £10 gas cooker http://www.gooutdoors.co.uk/hi-gear-por ... ve-p142491Pablobongo wrote:...will be easier to pay the european price for motorway tea/coffee
Not good in cold weather of course if gas canister is/gets cold, as gas doesn't vapourise properly (as I discovered, as late as April, when mine started belching out long lazy yellow flames about 1ft long. It was an interesting experiencefrancophile1947 wrote:Or get a £10 gas cooker http://www.gooutdoors.co.uk/hi-gear-por ... ve-p142491Pablobongo wrote:...will be easier to pay the european price for motorway tea/coffee
Err - he wants it to heat a kettle when stopping on the European motorways, so, unless aircon is fantastically over-effective, gas won't be coldmikeonb4c wrote:Not good in cold weather of course if gas canister is/gets cold, as gas doesn't vapourise properly (as I discovered, as late as April, when mine started belching out long lazy yellow flames about 1ft long. It was an interesting experience![]()
But not when the van's been moving. I assume he means stopping for a cuppamissfixit70 wrote:Deends where & when in Europe John, can still get 'kin cold.
Time you changed your avatar picture John......francophile1947 wrote:Err - he wants it to heat a kettle when stopping on the European motorways, so, unless aircon is fantastically over-effective, gas won't be coldmikeonb4c wrote:Not good in cold weather of course if gas canister is/gets cold, as gas doesn't vapourise properly (as I discovered, as late as April, when mine started belching out long lazy yellow flames about 1ft long. It was an interesting experience![]()
Don't go for one of these - they are very poor quality compared to similar ones you can get for a couple of quid more. I have also had gas escaping from them on a couple of occasions.francophile1947 wrote:Or get a £10 gas cooker http://www.gooutdoors.co.uk/hi-gear-por ... ve-p142491Pablobongo wrote:...will be easier to pay the european price for motorway tea/coffee
Most decent size inverters have to be wired in direct to the battery with decent size wiring, as you say Frank, avoid putting any load on the bongo ciggy lighter, the wiring is notoriously feeble.Diplomat wrote:I did some lateral thinking about heating water and came to the conclusion that a flask covers most of the occasions when I might need a kettle.
Otherwise a cheap and cheerful Bluet Camping Gaz Stove, a box of matches, and a small whistling kettle (very little heat loss and fairly spill proof). If you boil more than you use, pour it into the flask.
Don't even think about using 12volts with or without an inverter. It will melt your cigar lighter!
Keep the kettle for campsite hookups, though.
Frank
