Running cold V6
splash2
Running cold V6
Hi All,
I drove my Bongo from Gloucester to Bristol this morning, about 40 miles. The temperature gauge never moved - should I be worried?
A.
A.
Re: Running cold
Your thermostat is probably jammed open. It shouldn't cause any short term harm, but I'd get it sorted sooner rather than later.
- haydn callow
Re: Running cold
Could well be the above or a fault in the sensor/wire/gauge.......my V6 runs cool but the gauge moves up tp normal in a couple of miles.
Re: Running cold
Or else it hasn't got one - it has been known. Out of interest, does the gauge normally move to the 11.00 o'clock position then stay in that position all the time? Or has it been known to drift down a bit at times, especially when you are on the move?Ian wrote:Your thermostat is probably jammed open.
- haydn callow
Re: Running cold V6
Mike.....I think we can assume that things have been normal up to this trip....implication of that being a Stat is fitted.
Are the heaters working as normal ?? if so it points to a fault in the gauge circuit.....if not then a stuck Stat
Re: Running cold V6
Did your heaters get hot?
- haydn callow
Re: Running cold V6
Kirsty......beat you....that's a first....you must have dozed off!!
Re: Running cold V6
As an ex-Army bloke Haydn, you'll know the danger of assuming thingshaydn callow wrote:Mike.....I think we can assume that things have been normal up to this trip....implication of that being a Stat is fitted.
Better considered unneccessarily than overlooked unfortunately
Re: Running cold V6
I'm getting old nowhaydn callow wrote:Kirsty......beat you....that's a first....you must have dozed off!!
- haydn callow
Re: Running cold V6
at least we are thinking along the same lines and asking the same ???'s
Re: Running cold V6
haydn callow wrote:at least we are thinking along the same lines and asking the same ???'s
As an ex-army mate of mine once said to me "If all elses fails.....duck!"
Have a good Crimbo
splash2
Re: Running cold
Thank you all for your replies. Re the above: The gauge normally sits at 11 o'clock and never moves. There's not much heat coming from either heater.mikeonb4c wrote:Or else it hasn't got one - it has been known. Out of interest, does the gauge normally move to the 11.00 o'clock position then stay in that position all the time? Or has it been known to drift down a bit at times, especially when you are on the move?Ian wrote:Your thermostat is probably jammed open.
Re: Running cold V6
Have you checked the coolant level Splash2?
Re: Running cold
Hmmmm. Don't much like the sound of that. Have you checked your coolant level? If its low it isn't sufficient just to top it up as if air has got into the system meanwhile, it will need bleeding out. You shouldn't drive it until this has been been done as there's a risk of damaging the engine (although its the diesel that is well known to be damaged in this situation - not so much reported about the V6 or 2.0l petrol engines).splash2 wrote:Thank you all for your replies. Re the above: The gauge normally sits at 11 o'clock and never moves. There's not much heat coming from either heater.mikeonb4c wrote:Or else it hasn't got one - it has been known. Out of interest, does the gauge normally move to the 11.00 o'clock position then stay in that position all the time? Or has it been known to drift down a bit at times, especially when you are on the move?Ian wrote:Your thermostat is probably jammed open.
See if the techies agree with the above
PS - Bigdaddy already has (beaten me tuit
splash2
Re: Running cold V6
Yes - coolant level is right up to the top so I guess I need to investigate the state of the thermostat.
