coolant hose
roundspoon
coolant hose
Post by roundspoon » Tue Dec 28, 2010 1:52 pm
can anyone tell me the internal diameter of the coolant hose under the
drivers seat from the side of the engine to the bottom
heater pipe?
Re: coolant hose
Post by haydn callow » Tue Dec 28, 2010 1:57 pm
Pretty sure it's 34mm internal dia
roundspoon
Re: coolant hose
Post by roundspoon » Tue Dec 28, 2010 3:09 pm
Re: coolant hose
Post by Northern Bongolow » Tue Dec 28, 2010 6:06 pm
as i understand your question,you are after the dia of the over the starter motor hose????.
this goes from the back of the engine,drivrs side, down to the rear heater.
this measures 16mm internal,24mm external, 4mm wall thickness.
measured off old gen mazda hose.
Re: coolant hose
Post by haydn callow » Tue Dec 28, 2010 7:07 pm
AH !!!!!! that will teach me to read things properly.....
roundspoon
Re: coolant hose
Post by roundspoon » Tue Dec 28, 2010 7:25 pm
haydn callow wrote:AH !!!!!! that will teach me to read things properly.....
that 'll teach me to describe things properly
Northern Bongolow wrote:as i understand your question,you are after the dia of the over the starter motor hose????.
thats the one, just ordering some bits for when ive sussed the bleeding out :wink:
Re: coolant hose
Post by Northern Bongolow » Tue Dec 28, 2010 9:29 pm
be careful when you remove this hose at the heater end, if you suspect any corosion in the system, the place where this joins near the heater is known to corrode quite badly as its open to the elements. #-o [-o<
mikexgough
Re: coolant hose
Post by mikexgough » Wed Mar 02, 2011 12:18 pm
Just ordered a new one for tomorrow delivery........ mine has a hole at the block end on the "soft" non reinforced part....... fortunately I had noticed a slight drop in coolant level from normal...and decided to check out for a pinhole leak during level checks......then with engine running..... away "she" erupted .......from a pin hole....
