REAR DEMISTER & FRONT FOG LIGHT DASHBOARD LIGHT NOT WORKING
SPARKYSSS
Post by SPARKYSSS » Mon Jan 10, 2011 9:59 pm
Evening wonder if anyone can help me out please?
Just noticed that the lights on my dash for the rear demister and the fog light switch has stopped lighting???
Any ideas would be much appreciated
marc
(please explain like im a 7 year old as im a bit of a thickie)
daveblueozzie
Re: REAR DEMISTER & FRONT FOG LIGHT DASHBOARD LIGHT NOT WORK
Post by daveblueozzie » Mon Jan 10, 2011 10:03 pm
Fuse 20 is for the rear demister check that first
fuse 10 for dashboard.
or could be just the bulbs blown behind the dials.
Lost without my Bongo.
SPARKYSSS
Post by SPARKYSSS » Mon Jan 10, 2011 10:13 pm
HI Dave hope you are well.
Thanks for that. The rear demister is still working just not the light. Is that still the same thing?
jaylee
Post by jaylee » Mon Jan 10, 2011 10:16 pm
SPARKYSSS wrote:HI Dave hope you are well.
On light bulb gone..?
SPARKYSSS
Post by SPARKYSSS » Mon Jan 10, 2011 10:18 pm
How do you get at the pesky bulb please Jaylee?
Post by bigdaddycain » Mon Jan 10, 2011 10:29 pm
Hi Marc, is the actual foglight working?
jaylee
Post by jaylee » Mon Jan 10, 2011 10:29 pm
4 screws on the dash surrounding the speedo pod, then four more screws to remove the actual pod... Relevant bulb at the bottom right hand side? http://www.lushprojects.com/bongopartsm ... mgno=.html http://www.lushprojects.com/bongopartsm ... mgno=.html (no need pulling the whole pod apart, bulbs at the back.)
SPARKYSSS
Post by SPARKYSSS » Mon Jan 10, 2011 10:53 pm
bigdaddycain wrote:Hi Marc, is the actual foglight working?
Evening Ste
Yeah the fogs are all working just not the light on the dash
oh by the way i will be in touch in the next couple of weeks about my alloys if thats ok - just been hectic here
Post by bigdaddycain » Mon Jan 10, 2011 11:13 pm
Pm sent Marc :wink:
SPARKYSSS
Post by SPARKYSSS » Tue Jan 11, 2011 5:21 pm
With this in mind exactly what lights should be on the dash as if they are not working you wouldnt know????
Post by g8dhe » Tue Jan 11, 2011 8:49 pm
For the V6 there is Fuel Low, Air Bag, 4WABS, Alternator Charging, Brake, AFT, Main Beam, Left Turn, Right Turn, Rear Defrost, Belts, Door, Hold, then the 6 gears P, R, N, D, S & L;
SPARKYSSS
Post by SPARKYSSS » Tue Jan 25, 2011 9:44 pm
Still havent got round to this little job so will probably have a stab at the weekend. Any ideas wich bulb the fog light notification light will be please?? I know its on the group of 6 on the right but wich one??
jaylee
Post by jaylee » Tue Jan 25, 2011 10:17 pm
SPARKYSSS wrote:Still havent got round to this little job so will probably have a stab at the weekend. Any ideas wich bulb the fog light notification light will be please?? I know its on the group of 6 on the right but wich one??
High chances are... You don't have a factory fitted fog light notification light for the front!!
... Definitely not for the back fog. :roll:
I made my own for the front... & the back. :idea:
Post by bigdaddycain » Tue Jan 25, 2011 10:41 pm
Marc, there is a notification bulb (orange) for the rear demister in the main dash lights, but the rear fog will be an aftermarket switch as bongo's don't have rear foglights in Japan. For the sake of a cost of a switch (a couple of quid) i'd swap the switch over to remedy the failed bulb issue, available at most car accessory shops (motor world etc). The switch will need to illuminate for an MOT pass. :wink:
SPARKYSSS
Post by SPARKYSSS » Wed Jan 26, 2011 3:52 pm
Is the top section of this light supposed to light up?
http://s822.photobucket.com/albums/zz14 ... G00102.jpg
Also the panel in the right hand side of the instrument cluster with the 6 windows in - is it a different bulb for each window?
sorry to be such a thickie
Or then again could it be a fuse???
