Electric problems
Posted: Sat Jan 29, 2011 7:10 pm
by bongobaz
Hi folks coouple of probs with electric
Rear window demister not working {dash light is on}
Central locking not working [the one that opens all doors from drivers door]
Could these be connected?
Checked fuse 4 under dash seems ok,
Loom at door hinge looks ok but not realy dragged it all out for a good look,
its a bit bent up and i nearly got run over!
Re: Elctric problems
Posted: Sat Jan 29, 2011 7:27 pm
The Rear demister fuse itself is Image if the light is coming on the switch then the other fuse Image should be OK.
The Power door lock control is fused by Image and the fuse that controls the solenoids themselves is Image
There doesn't seem to be any common features between the two circuits that I can see at the moment ...
Posted: Sun Jan 30, 2011 12:33 pm
by bongobaz
Thanks for that, i will have another mooch about.
