Chipped Speedo
maxi_77
Chipped Speedo
Post by maxi_77 » Wed Feb 02, 2011 11:06 am
Our new shiny white Bongo has a chipped speedo, I haven't dealt with one of these before, can I simply remoove it as we are in Portugal and kilometres are much easier for us than miles
White diesel Bongo
321Away
Re: Chipped Speedo
Post by 321Away » Wed Feb 02, 2011 1:30 pm
yes, just remove the closk set and the chip usually situated behind them, just reconnect the blue/white wire in the centre loom (or right hand loom depending on age of vehicle) and vehicle will read in kms. Some converters put the chip on the gearbox
Julian
maxi_77
Re: Chipped Speedo
Post by maxi_77 » Thu Feb 10, 2011 1:26 pm
Just got in behind the speedo, and found the chip, a small black plastic box with four wires, three, blue red and green are attached to the flexible circuit with screws. I assume you simply disconect and replace screws. the fourth yellow wire is connected to the side of the blue and white wire coming from the loom. I connect this blue and white wire to the bit sticking out of the middle connector from the loom to the flex circuit.
Sorry to be pedantic but sitting out here in the Algarve help is a long way away if I cock it up.
White diesel Bongo
westonwarrior
Re: Chipped Speedo
Post by westonwarrior » Thu Feb 10, 2011 7:13 pm
you are correct
make sure the screws go back in and are tight enough not to come loose
maxi_77
Re: Chipped Speedo
Post by maxi_77 » Mon Feb 14, 2011 10:19 pm
westonwarrior wrote:you are correct
Thanks, did the job yesterday speedo now giving good readings in Kms, much easier here.
Thanks for your help.
White diesel Bongo
