Starter not turning
sirclugs
Starter not turning
Post by sirclugs » Mon Feb 14, 2011 8:50 am
Hi Folks,
Relatively new to Bongo-ing, bought my Bongo 2.5TDI last summer. I ran away from the cold to West Africa for 4 months and just returned but de Bongo no go start, she feel neglected. Batteries (I fitted Martin Bird's split charging System) both charged, turn on ignition, all looks well, Coolant alarm shrieks at me briefly. Turn key to start - nothing, no click, some panel lights go out. I notice sedimentor light is on, I'll deal with that later. Gear in Park, foot on brake, what other inhibits have I forgotten? Help, I need to go to Tescos for breakfast. Any clues gratefully received. Searched the forums but it just tells me "No suitable matches were found". I see comments about the contactor but I don't even hear a click.
Sir Clugs
Re: Starter not turning
Post by mikeonb4c » Mon Feb 14, 2011 10:19 am
sirclugs wrote:Hi Folks,
Sir Clugs
First suspects sound like u/s starter battery (can't provide power for anything more straining than a light bulb, beeper, w.h.y.) or else starter motor solenoid stuff, which has happened to several owerns. Provided your Bongo is not the North Japan model (came with 2 starter batteries), which has a different starter motor, then you can purchase a repair kit, which is a lot cheaper than a new starter motor. Not a hard job to do it I gather. Search again as its all on here (or check members area factsheets, if you are a paid-up member)
Post by g8dhe » Mon Feb 14, 2011 10:21 am
You might check fuse Image as this drives the Starter relay, if no joy with that then the contactors / starter solenoid sound like the next likely thing.
wonkanoby
Post by wonkanoby » Mon Feb 14, 2011 10:24 am
http://cgi.ebay.co.uk/MAZDA-BONGO-FORD- ... 3a62fadb86
is the kit but my gut feel is your starter batterys had it
will it jump start
sirclugs
Post by sirclugs » Mon Feb 14, 2011 12:22 pm
Thanks for the quick replies.
I don't think its the battery, if I put the headlights on they do not dim when I turn the start key so the voltage is not dropping from starter load. Either its inhibited or the solenoid is sticking. I have ordered up a kit from ebay.
Sir Clugs
Dave.
Post by Dave. » Mon Feb 14, 2011 12:31 pm
tap the starter motor (under drivers side) nice firm knocks ,also check the spade terminal on the rear of the starter ,lastly if you removed the battery check the earth strap is re-attached
It is probably just stuck from standing 4 months id say hitting it a few times should sort it :)
321Away
Post by 321Away » Mon Feb 14, 2011 2:15 pm
sticking solenoid all day!! as they said, turn key into cranking position and give it a few firm knocks, if not then whip it out and replace the solenoid contacts, assuming you dont have the HD type.
Julian
sirclugs
Post by sirclugs » Mon Feb 14, 2011 5:04 pm
Sorted chaps, many thanks for your help. It was a rather loose connector on the starter solenoid. Cleaned it and squeezed it up a bit. The sedimentor light has also gone out now its running.
Sir Clugs
wonkanoby
Post by wonkanoby » Mon Feb 14, 2011 5:11 pm
still worth looking at the contacts
as one side wears right away and was as thin as a fag paper on mine
