Where to get passenger side EGR pipe WL0120310?
jwhitham
Post by jwhitham » Mon Feb 14, 2011 1:04 pm
Anyone know a source of pipe 20-310 that goes from the exhust manifold to the EGR valve? Looked at ava lesuire, Bongo Fury shop etc can't find one. Even searching whole of google with part number only has one result, the lushprojects engine manual.
I have a big hole in mine where it's looks like it's been weleded in the past. It makes a lot of noise and seems to be loosing power.
I bought a set of plates to close of the EGR but they only blank it on the drivers side (inlet manifold) so it wont help with my hole.
My other thought is trying to find a large plumbing type endcap that will screw onto the exhaust manifold instead of the EGR pipe. I'm thinking it would need to be the same metal or differing expansion / contraction rates would be a problem?
Anyone else had this pipe go?
321Away
Re: Where to get passenger side EGR pipe WL0120310?
Post by 321Away » Mon Feb 14, 2011 2:13 pm
I've seen them go around the weld where it meets inlet elbow, just clean it up and get it re-welded?
Julian
Post by Northern Bongolow » Mon Feb 14, 2011 3:39 pm
the pipe you mention is 22mm od, so a temp repair with a standard fitting should be easy if you go down that route,
if you blank everything off,dont forget about the rocker/crankcase breather that loops into this pipe at the rear of the head.
Dave.
Post by Dave. » Mon Feb 14, 2011 4:27 pm
I have one spare :) pm me
Post by Northern Bongolow » Tue Feb 15, 2011 5:55 am
Northern Bongolow wrote:the pipe you mention is 22mm od, so a temp repair with a standard fitting should be easy if you go down that route,
thanks kirsty----------im talking out of my pipe again :shock: :lol: . the rocker breather of course goes into the air/turbo pipe next to the egr pipe. glad your keeping an eye on things =D> .
jwhitham
Post by jwhitham » Tue Feb 15, 2011 2:16 pm
Thanks for all your replies.
I think I'm going to try getting it welded.
