Three hoses are weeping at the ends where they are fastened to the engine or metal pipes. It'll need to go back to the dealer tomorrow to get looked at but that's a journey of about 30 miles. As the pipes seem to be leaking at the connections should this be a fairly straight-forward job of just tightening the clips or is this realistically a system-drain/hose/thermostat replacement?
Should I risk the drive to the dealer's just topping up the coolant if the coolant alarm goes off along the way? I've also got a temperature alarm waiting for me to fit - should I fit this before going or just leave as is rather than risk an issue with warranty etc?
