Head gasket bolts and poundage
paulwooding1973
Post by paulwooding1973 » Fri Mar 18, 2011 10:38 am
The head gasket has gone on my Bongo and my garage need some technical data. Apologies for any errors in the following request but it's all a bit Greek to me!
They need to know when replacing head gasket – do we need new cylinder head bolts (are the Bongo ones throw away) and if so, so what is poundage/newton metres/degrees to tighten it down with.
I have an N-reg 2 wheel drive diesel with the original engine (as far as I know)
If anyone can help me out on that it would be much appreciated!
Paul
MAZABON
Re: Head gasket bolts and poundage
Post by MAZABON » Fri Mar 18, 2011 10:54 am
hi
dont know on the torque setting but i believe its recomended that new head bolts are used
just found this on another thread
Tightened bolts hand tight and then four times to torque settings 22 ft/lbf (Bongo manual says 4 times, Ford ranger says 3)
Then put a paint mark on all the bolt heads and turned in sequence 90º
Then once more to a further 90º turn.
link to thread http://www.igmaynard.co.uk/bongo/forum/ ... ue#p401141
best wait for someone to confirm its correct though
widdowson2008
Post by widdowson2008 » Fri Mar 18, 2011 11:43 am
From Mazda manual, torque setting is 29Nm (3 to 4 times as said before).
However, there is a procedure Mazda have laid out. If you want this sequence, send me a pm.
Steve
Dave.
Post by Dave. » Sat Mar 19, 2011 12:09 pm
More importantly make sure the head is skimmed and pressure tested (costs around £50)
Its a common fault with bongo's
If that garage say no need please insist it is done other cars you can get away with bongo's you cant
Make sure he looks at the bleeding a bongo cooling system on you tube also (as he isnt familiar with bongo's by the sounds of it)
Also it will pay for you to watch the you tube bleeding bongo vids
If he doesnt your head will blow again before you get it home .
progroup
Post by progroup » Mon Jun 13, 2011 1:03 am
Has anyone found where to get the small "O" ring that fits on the block [between #2 & #3 cyl.]?
Post by haydn callow » Mon Jun 13, 2011 10:39 am
Fitting a new head gasket is not "normally" a fix......as said above get the head tested or you may find you are going through all this again very soon......has you garage done bongo's before...if not...as above....MAKE SURE THEY FOLLOW THE BLEEDING INSTRUCTIONS (contact me for a copy) and watch the vidio's (search "bleeding bongo's on UTUBE)
And yes!! you do need to fit the correct new head bolts.....available from the bongo shop...as is gaskets and cylinder heads
Post by teenmal » Mon Jun 13, 2011 12:24 pm
paulwooding1973 wrote:Hi
Paul
Hi paulwooding1973,
That is very interesting,did the mechanic or yourself actually see the burst in the head gasket.
Hope everything goes ok for you.
Cheers.
progroup
Post by progroup » Mon Jun 13, 2011 1:48 pm
Please see my pics at:
http://www.dropbox.com/gallery/11334027 ... n?h=2b1c96
Does anyone know about the small O-Ring that goes between the head & block [as depicted in 8 pics] :?: :?:
Post by teenmal » Mon Jun 13, 2011 3:49 pm
progroup wrote:Please see my pics at:
Is it the o-ring seal on the oil feed spigot that you are referring too,you should get a new one with your set,other than that you will get one from a factor or engine rebuild centre.((its not worth refitting the old one))
Cheers.
Post by mikeonb4c » Mon Jun 13, 2011 5:23 pm
Paul
Dulwich, London!?!?!?!?! That's where I grew up. The Bongo truly has come home 8)
Welcome, and sorry that's not relevant to what you needed to hear 8)
progroup
Post by progroup » Mon Jun 13, 2011 7:27 pm
I called my UK supplier - as it turned out they had opened the head set to remove the valve guide seals [not required for a built head], and must have droppped the little bag containing all the rubber based seals. They are sending a set out today! :D
Post by teenmal » Mon Jun 13, 2011 7:52 pm
progroup wrote:I called my UK supplier - as it turned out they had opened the head set to remove the valve guide seals [not required for a built head], and must have droppped the little bag containing all the rubber based seals. They are sending a set out today! :D
Great stuff.
Cheers.
