Rear Caliper Seal Kit
bongo barney
Post by bongo barney » Sun Mar 20, 2011 5:34 pm
Can you help me. I've just taken receipt of a rear caliper repair kit does anybody know what the orange grease (large packet) and the white grease (Small packet) are to be put on? The instructions in the kit are in Japanese.
Cheers Barney
wonkanoby
Re: Rear Caliper Seal Kit
Post by wonkanoby » Sun Mar 20, 2011 5:45 pm
one should be real thick and thats the one intended for use on piston and bore and seal
the other will be thin stuff for greasing the moving bits were metal slides on metal
were did it come from they should tell you
if unsure chuck them and go buy some
bongo barney
Post by bongo barney » Sun Mar 20, 2011 7:54 pm
Thankyou for the reply
Here goes for tomorrows repair armed with some info Margo the Bongo should be fixed .
I got the kit from Japanese Automotive solutions I assume they are OK .
As an aside I got my brake pads from them, the box is marked Xedos 9 Range does that mean that a Xedos Caliper would fit a Bongo?
Barney
