key cutting for Bongo
We successfully got our spare key cut at TIMSONS on the high street costing £8 ,standard non remote key.
Re: key cutting for Bongo
That's where I got my keys done, have had loads done over the years, they were about just about the first place to be able to code transponder keys as well.Barley 1981 wrote:We successfully got our spare key cut at TIMSONS on the high street costing £8 ,standard non remote key.
A Quote from Steviebongo re the AA that might help someone..
Quote....
We have a AA man around here that specailizes in keys his van is kitted oot and can cut and code any keys to suit any car I've been told he even has a tool to read door barrels without the need to remove the lock or get into the car !so if urea member or now somebody that's one I would give them a call ,might save a lot of hassle
Quote....
- TechnoTurkey
My local cobbler did mine no problem at all, don't be conned by the eBay sellers saying that only they can supply the blanks....
Member 10,000!
1997 Green AFT 4x4 2.5TD Auto Bongo
CobblersTechnoTurkey wrote:My local cobbler did mine no problem at all, don't be conned by the eBay sellers saying that only they can supply the blanks....
Bongo no more........... ;-(
My local cobbler did me two for a tenner, fit and work perfectly.
- Bongonaut
I got mine done by a chap in a layby between Newton Abbott and Paington. He was parked in the layby in a bongo! He had strings full of keys hanging in the back and running the length of the bongo. He had a basic keycutting machine which was powered by 2 x 12v car batteries and was using the Bongo as his workshop! Really nice bloke and only charged a couple of quid per key.
tony where was this,i went to the one in wimborne but he didnt have the right blank..jez
If the blank you need is like the one here http://www.ebay.co.uk/itm/Mazda-Bongo-F ... 4aab3ff54dchipvan wrote:tony where was this,i went to the one in wimborne but he didnt have the right blank..jez
...let me know and I'll stick one in the post to you FOC. I ordered one and it was no good for me - I've got one of the rarer keys which is slightly different to this one (the taper at the end).
Two tonne tin drum
Your a star,but mine doesent look like that type,will get a pic up later.
