Post
by 321Away » Mon Mar 28, 2011 12:26 pm
Under the passenger seat , about middle of the engine, you can see a (bit of ) bar running horizontally,From the back of acttuator, you can identify this byt following pressure pipe (about 1.5cc dia) from the rail (just inside the engine bay, nearest your legs)runs up to the atuator on the engine, on the other side of the big diaphragm housing you'll see the actuator rod, try moving it a few times, esp once yopu have the flashing light,BE CAREFUL whole area is very hot!
If it moves freely, get under the drivers seat and check the vacuum control valves, they are on the rail (again nearest your legs) almost at he back of the open space, 3 horzontal, your interested in the rear most vertical, if this died, it will cause your sypmtoms, changing may give you a temporary fix, but if you do lose power when the light flases its most likely to be the turbo gasket.
julian
