Another coolant question
Hi over last few weeks the Bongo has been spitting coolant out from somewhere high up as it is on the inside of the bonnet and the intake vent. If i am filling up with too much coolant will it spit it back out? Header tank still registers about 15mm on my stick after this happens.How much should it come up the stick? Doesnt do it every trip and doesnt seem too hot could it be the rad cap?(looks like original one with jap writing on)
Re: Another coolant question
Cheers so after losing coolant i still have 15mm on my stick may suggest i am overfilling?
I don't know how much your putting in to loose it down to 15mm... If you dip yer stick vertically to touch the bottom, 20mm is just the right amount to top up to!
Need a coolant boffin fer the spitting antifreeze...
to establish the correct fill level just fill to the high mark on the expansion tank when the engine/coolant is cold, if you have a discoloured tank and cannot view the level through it, its as jaylee says, approx 20mm up a lolly stick held verticle.stuc wrote:Hi over last few weeks the Bongo has been spitting coolant out from somewhere high up as it is on the inside of the bonnet and the intake vent. If i am filling up with too much coolant will it spit it back out? Header tank still registers about 15mm on my stick after this happens.How much should it come up the stick? Doesnt do it every trip and doesnt seem too hot could it be the rad cap?(looks like original one with jap writing on)
this does sound like you have a leak somewhere in the coolant system, or a faulty cap on either the rad or expansion tank, or a split rad.
would suggest a pressure test,and a cap test and take it from there,and would suggest you dont drive it until you get to the bottom of it.
- mikexgough
If the coolant is spitting out high up then could be the top rad hose with a pin hole or one of the exp hoses with similar......could be when the engine gets hotter than usual the pin hole opens up and erupts coolant ...worth a check, leave the engine running after a trip and lift the bonnet, if there is a pin hole it will soon make itself known..... 5mm drop doesn't suggest a big leak to me...stuc wrote:Hi over last few weeks the Bongo has been spitting coolant out from somewhere high up as it is on the inside of the bonnet and the intake vent. If i am filling up with too much coolant will it spit it back out? Header tank still registers about 15mm on my stick after this happens.How much should it come up the stick? Doesnt do it every trip and doesnt seem too hot could it be the rad cap?(looks like original one with jap writing on)
Has the rad been changed at any point for a non standard one with a vent under the rad cap? If so this should be blocked off as it's not necessary & will cause problems, as any venting should take place at the header tank cap (1.1bar only). The cap on the rad should not be able to vent at all so it is not really relevant what pressure cap is fitted.
Is the header pressure cap sealing ok?
- TechnoTurkey
As is to be expected, Kirsty has a very valid point - this is what was causing my coolant leak, never more than a quick squirt but enough to set my nostrils tingling and my brain to panic!
Member 10,000!
1997 Green AFT 4x4 2.5TD Auto Bongo
Hi rad has got an overflow next to the cap. Do i need to block this off? Pressure tested the caps today and both were letting go at 0.8 bar so two new caps i reckon. Wheres the best place to get them, local factors ,ebay or is genuine parts best?
- widdowson2008
The overflow at the main rad needs to be blocked off. You will not need a new cap here because all it is doing is blanking off the radiator. Just check that it is sealing correctly.stuc wrote:Hi rad has got an overflow next to the cap. Do i need to block this off? Pressure tested the caps today and both were letting go at 0.8 bar so two new caps i reckon. Wheres the best place to get them, local factors ,ebay or is genuine parts best?
The expansion tank however DOES need a cap rated at 1.1bar.
Steve
Any suggestions on best way to seal off this overflow.
I haven't done this myself but I understand that people have used a piece of pipe with a bolt as plug with appropriate hose clamps etc.
Someone will be along shortly with the right advice.
Deja vu anyone? - http://www.igmaynard.co.uk/bongo/forum/ ... 71#p492871
- TechnoTurkey
I used a short bit of pipe with a bolt rammed down it and a jubilee clip at each end, has been perfect.
Member 10,000!
Thanks for that, sorry i wasnt paying attention i will give myself a telling off and go stand in the corner with a dunses hat on.
