whistling, screeching fan belt??
- Bongomamma
- Junior Bongonaut
Hi, our new bongo has a squeechy whistly type noise on start up and for a few minutes, I wondered whether this was the fan belt?? Anyone any ideas and can give me a heads up if this is in fact a fatal issue?
Re: whistling, screeching fan belt??
could be
could also be front most stud on exhaust is broken as thats very common
as said above, do a search (top right tab) and enter key words, no 1 manifold stud,that may help.
- mister munkey
Manifold stud will sound a bit like an angry budgie under the passenger seat,
Have a look through this thread http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=35620
Similar symptons???
Similar symptons???
Bongomamma wrote:Hi, our new bongo has a squeechy whistly type noise on start up and for a few minutes, I wondered whether this was the fan belt?? Anyone any ideas and can give me a heads up if this is in fact a fatal issue?
Hi check the tension of the belts,also check the side profile of the belts for wear and glazing.
Cheers..
I had a similar noise for a few minutes after start up. Turned out to be the idler pulley on the aircon belt.
- Bongomamma
- Junior Bongonaut
thanks, my other half has a really big "to do" list today
Turned out to be the idler pulley on the aircon belt....had similar
a spray of grease shut it up for a week but in the end got a new bearing from a mazda dealer
