tow bar fitting?
jutwit
tow bar fitting?
Post by jutwit » Sun May 15, 2011 12:43 pm
how hard is it to fit a tow bar? im more concerned about the electric side of it, or is it a professional job?
M 80NGO
Re: tow bar fitting?
Post by M 80NGO » Sun May 15, 2011 4:16 pm
Its a fairly straight forward job as long as you have the correct towbar for your vehicle and arn't trying to fit a one size fits all type setup, as for the electrics they're taken off the o/s rear light as there is access from underneath for the wiring to pass through and the wiring won't be anywhere near the exhaust which exits on the n/s :wink:, i recon an afternoon should have it done comfortably :D
lazyb5
Post by lazyb5 » Sun May 15, 2011 5:23 pm
Yep about an afternoon but with the one i fitted it had a mid connection as well as the two ends and you needed to drill a hole through the rear of the car. Instructions were ok and if followed was ok. Got it off ebay.
