LED Fog Light bulb - Facelift Bongo
My new shape Bongo has one of the reversing lights converted to a fog light by replacing the bulb with a red one and rewiring to a new switch on the dash. I assume this was done by Imperial when they imported and converted it.
The fog light isn't very bright so I want to replace the red bulb with a red LED bulb but I understand that the bulb type is different on the new shape. Has anyone on here done this and can advise me on the right LED bulb to buy?
I have already tried the search function and found loads of reference to bulbs for the older style but nothing for the facelifted Bongo.
Re: LED Fog Light bulb - Facelift Bongo
29 views and no replies? Surely someone must have done this or know what type of bulbs are used in the facelift rear lights?
Hi,Poohbear wrote:29 views and no replies? Surely someone must have done this or know what type of bulbs are used in the facelift rear lights?
I think you will find it quite hard to find a led bulb,and even a true red bulb.
Why do you want to change to a brighter bulb,did it fail the MOT.
http://www.lushprojects.com/bongopartsm ... 1of02.html
No, just because it's not very bright. I have the same problem with the single reversing light which is obviously the same type of bulb but white.rita wrote:Why do you want to change to a brighter bulb,did it fail the MOT.
Has nobody on this forum changed the reversing or fog lights on the new shape / facelift models or are they just not speaking to me?
Poohbear wrote:Has nobody on this forum changed the reversing or fog lights on the new shape / facelift models or are they just not speaking to me?
Hi,did this not help you,..
these vehicle do not have FF rear fog lamps.
Poohbear.............Poohbear wrote:Has nobody on this forum changed the reversing or fog lights on the new shape / facelift models or are they just not speaking to me?
I've tried to find LED bulb(s) for the reversing light but failed miseribly... They are a type of wedge bulb but they are W18W or seemingly W16W...... I've asked a number of bulb suppliers and none of them do an LED equivalent.
PLEASE if you do find something let me know Thanks.
Terry
PS I have a 2001 model
I'm sure DBO has replaced his for LED's....AeroNut wrote:Poohbear.............Poohbear wrote:Has nobody on this forum changed the reversing or fog lights on the new shape / facelift models or are they just not speaking to me?
Terry
