Lever next to air scoop?
Hi just noticed under bonnet next to air scoop (big black plastic bit ) that you take off to get to rad cap that there is a lever that can be moved between 2 positions, anyone know what this doesand should you move it t all, maybe a summer and winter setting or something?
Re: Lever next to air scoop?
Summer and Winter indeed
Ok, not a bad guess then. Do you know which is which and when if you should switch over?
- roofraisers
Use with the lever forward during normal climate (summer) & with the lever pushed back in the winter.Not sure it gets cold enough for long enough to make that big a difference though in the UK...unless we get more -20*C for a few weeks around the new year!
Nigel
Nigel
Is there any one who has any pics of this leaver?had a look and all I can see is a metel rod with a hole in it,maybe the leaver is missing?looks like the flap inside where the fan is moves forward in the Summer but don't know how much by,I will have a go with a spanner to turn flap but don't want to go too far and soap anyting!
chipvan wrote:Is there any one who has any pics of this leaver?had a look and all I can see is a metel rod with a hole in it,maybe the leaver is missing?looks like the flap inside where the fan is moves forward in the Summer but don't know how much by,I will have a go with a spanner to turn flap but don't want to go too far and soap anyting!
Noooooo!!!!, no need, if it ain't there, you ain't got it, never had it & don't need it or need to worry about it
Cool,don't like thinking iam missing out on something!!!!thanks all the same just in a tinkering mood
some intake flaps are servo operated fron inside the intake unit, do you have a digital heater control unit?
Got a Bongo for the Wife, Best trade-in ever
Yours is probably the digital climate control? it's controlled by the recirc button (top left) on an actuator (just had to go out & confirm on mine
Yes got dig climate control
