1995 2.5 tdi auto 4wd
Hobbsy
Hi all, just got my first Bongo, and know nothing about them... th Cambelt was done in 2007 - 30,000 miles ago, anyone know when these are supposed to be changed, is this a big / expensive job? any help appreciated!
Re: 1995 2.5 tdi auto 4wd
There's a factcsheet, along with many others in the members area (well worth the few quid that it costs) but I think you're too late to join now before Ian sets off for the Bash in Stourport.
Service interval is 100,000km for the cambelt I think, so you're probably about halfway there, nowt to worry about for a bit.
Most important thing to familiarise yourself with is the cooling system, consider a low coolant alarm or Mason alarm (search function will reveal all) or at the very least modifying the temp gauge to read sumat useful (fairly well dumbed down as standard).
Hi everything that missfixit said and welcome to the forum. Fact sheets are a great bedtime read.
If you put your location in your sig then you may find your near someone who can pop round and advise.
Hobbsy
thanks guys, I will look into that, dont mind contributing to the forums, Im a member of a few as it goes! With the cambelt change, is there a time limit though as it was september 2007?
I will also look into modifying my profile, im from Newport,s wales!
Approx every 5 years.Hobbsy wrote:thanks guys, I will look into that, dont mind contributing to the forums, Im a member of a few as it goes! With the cambelt change, is there a time limit though as it was september 2007?
Cheers.
