Towing tips
Travis
Towing tips
Major possibility that I will have to get towed from behind out a muddy field. Any tips? Do I just slip auto gear box into N? Should I try and get tractor in front? Where do I put hook? Some folks here in big camper vans already had towing ring snapped.
Travis
Travis
- Alacrity
- Tribal Elder
Re: Towing tips
I would put it in S with the hold button engaged myself. If its muddy don't try to pull away in D without the hold engaged.
Travis
Re: Towing tips
Is that driving. I was thinking I may be towed out by a tractor
TrAvis
TrAvis
- Alacrity
- Tribal Elder
Re: Towing tips
Towed out? In a Bongo. Nah! I would still do the same though just to help relieve the load. I take it you are 4x4?
Travis
Re: Towing tips
No not four wheel drive. I just want to towed while not driving. Is it just N?
- Alacrity
- Tribal Elder
Re: Towing tips
N with the engine running then.
Travis
Re: Towing tips
? Engine running?
Re: Towing tips
Travis wrote:? Engine running?
If you have the engine running the oil pump for the auto-box will be working,also you will have Brakes if you need to stop in a hurry.The Tractor driver will probably keep you right,regarding the actual tow.
The best of luck.
Cheers..
- Alacrity
- Tribal Elder
Re: Towing tips
Rita is correct. Never tow an auto without the engine running, see THIS THREAD
Travis
Re: Towing tips
Should never have doubted the bongo. Everyone getting towed out for £40 a go by the AA. Slipped him to S with hold pulled away first thing, no probs. Thanks everyone.
Travis
Travis
Re: Towing tips
Ah now I see the problem......slipped HIM into S.....it's a MALE Bongo.....males can't multitask.....if it had been a HER.then there would have been no worries...
....that's what the wife told me anyway.....
Alan
Alan
Alan...still plodding on....!
