Fuel Gauge
Two R's
Fuel Gauge
Post by Two R's » Thu Jun 30, 2011 4:46 pm
Looks like it's suddenly been posessed. Drove about ten miles the other day and appeared to lose half a tank. The needle then stuck on the quarter full mark and stayed there for the next 60 miles. Sometimes creeping up...yaay!..then back..boo!!
Set off the next morning and it showed over half full again!
Seems to have settled a bit now, but have no idea how much juice is in there.
It's due a service, but am wondering if it's easy to fix myself with my zero garage skills.
Stupidity is the basic building block of the universe - F.Zappa
Re: Fuel Gauge
Post by haydn callow » Thu Jun 30, 2011 4:47 pm
loads of topics on here (have a search)....You will need to add a earth wire either at the sender or Fuel tank to body
Mike&Katie
Re: Fuel Gauge
Post by Mike&Katie » Thu Jun 30, 2011 4:49 pm
Its real easy to do, it was one of the first things i fixed on my van and i'm by no means a mechanic.
Have a search on the forum and you will find loads of info.
Mike.
daveblueozzie
Re: Fuel Gauge
Post by daveblueozzie » Thu Jun 30, 2011 7:20 pm
Have a look at this post it might help.
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=48363
Lost without my Bongo.
Two R's
Re: Fuel Gauge
Post by Two R's » Thu Jun 30, 2011 8:10 pm
Cheers. I'll have a look, although I'm not sure I can get in that way as we have a side conversion behind the drivers seat.
Re: Fuel Gauge
Post by g8dhe » Thu Jun 30, 2011 8:43 pm
If you can't get at the tank because of the side conversion there is another way, by adding and earth strap to the tank from below, this also described in detail by 321Away here.
