what are these wires for? what switch used to live here?
hz0j3m
Post by hz0j3m » Sat Jul 02, 2011 4:33 pm
Hi guys, at the rear, nearside of my bongo interior is a small circular hole with 2 electrical connectors hanging from it. Any ideas what they do please?
The hole is to the rear of the plastic molding that houses the blind switch and a couple of cubby holes
Hope the description is clear, I'll try to post a photo if needed
Many thanks :D
Re: what are these wires for? what switch used to live here?
Post by Northern Bongolow » Sat Jul 02, 2011 4:39 pm
rear ciggy lighter ???.
nigelgibson
Post by nigelgibson » Sat Jul 02, 2011 5:01 pm
sounds like ciggy lighter but check there isn't a black box behind the panel as this would indicate a 110v inverter which has been found on a few. [ see seperate threads on here for this]
hz0j3m
Post by hz0j3m » Sun Jul 03, 2011 11:35 am
Thanks guys, ciggy lighter it is - should've thought about checking for voltage first!
All the best
jaylee
Post by jaylee » Sun Jul 03, 2011 3:45 pm
I wouldn't be chancing using an actual cigarette lighter in there... OK as a phone charger & the like! :D
