Windscreen rust
dom_e
Windscreen rust
Post by dom_e » Wed Jul 13, 2011 10:46 pm
The dreaded tin worm has begun eating away around the windscreen along the sides. There's a gap between the metal and outer seal rubber and there are some holes in the rubber. It seems that water/dirt has collected and allowed it to fester and rust.
It's not too bad at the moment, but will need sorting. I know that a few others have had this issue tackled, but how was the outcome and at what cost?
It strikes me as a potentially expensive problem, but I'm hoping not! How many members has this issue effected?
Ta
Dom
Beyond A to B
ptatham
Re: Windscreen rust
Post by ptatham » Thu Jul 14, 2011 2:47 pm
Rust bubbling under windscreen caused mine to crack. Luckily Autoshield man didnt mind and fitted new screen under insurance. I had to grind out rust and weld in couple of fresh bits of steel. Apparently its quite common. Welding was easy enough, but made a mess of dashboard grinding old stuff out.
dom_e
Re: Windscreen rust
Post by dom_e » Thu Jul 14, 2011 4:40 pm
I thought that windscreen replacement cos. wouldn't replace windows with rust.
Beyond A to B
hembramacho
Re: Windscreen rust
Post by hembramacho » Thu Jul 14, 2011 6:33 pm
I had similar troubles recently - see here.
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=47247
Andrew
dom_e
Re: Windscreen rust
Post by dom_e » Thu Jul 14, 2011 9:09 pm
Thanks. I'd seen that thread before I noticed the prob with mine. Mine is nowhere near as bad, but It'd be good to 'nip in the bud'. Out of interest, what was a ball park figure for the work if you don't mind saying? Was the windscreen removed?
Thanks.
Dom
Beyond A to B
hembramacho
Re: Windscreen rust
Post by hembramacho » Fri Jul 15, 2011 5:49 pm
PM sent.
