Soundproofing
psquiddy
Soundproofing
Post by psquiddy » Tue Jul 26, 2011 9:48 pm
I have got a 1996 2.5td and am thinking about trading it in for a newer model or spending some money on it and making it nice.
One of my main gripes about it is the engine noise - it seems to get really loud at about 2500 rpm, then gets quieter above that - is that right or is it some sort of illusion?
Are there any ways of reducing the engine noise e.g. thicker carpets
Over 300 free things to do in London
http://www.toplondondaysout.co.uk
321Away
Re: Soundproofing
Post by 321Away » Wed Jul 27, 2011 8:43 am
possibly the turbo spooling down from max rpm?
Julian
Velocette
Re: Soundproofing
Post by Velocette » Wed Jul 27, 2011 10:27 am
psquiddy wrote:I have got a 1996 2.5td and am thinking about trading it in for a newer model or spending some money on it and making it nice.
I've soundproofed other cars usually with a type of special felt underlay bought from a car accessory shop. It would be fiddly on the Bongo though. Also it might make the engine bay even hotter.
I know what you mean it can be quite hard to hold a conversation at Motorway speeds sometimes.
Re: Soundproofing
Post by rita » Wed Jul 27, 2011 10:46 am
You could try a couple of these :idea: :lol:
http://www.ebay.co.uk/itm/Telex-Dual-Mu ... 1e65013979
Velocette
Re: Soundproofing
Post by Velocette » Wed Jul 27, 2011 11:37 am
That would just encourage her! :wink:
Re: Soundproofing
Post by missfixit70 » Wed Jul 27, 2011 1:22 pm
May sound daft, but check the clips holding the front seats down are tight, most I've seen are slack, just needs a few taps with a hammer to reshape the clips tighter.
Is there any insulation under the seats etc on yours? I've seen one or two where it's not there.
Re: Soundproofing
Post by teenmal » Wed Jul 27, 2011 8:21 pm
Hi psquiddy,
A long shot,but do you have the undertray fitted?
Cheers..
Re: Soundproofing
Post by missfixit70 » Wed Jul 27, 2011 8:25 pm
teenmal wrote:Hi psquiddy,
Cheers..
Good thinking :wink: & does it have the sound deadening on it if it is fitted?
psquiddy
Re: Soundproofing
Post by psquiddy » Thu Jul 28, 2011 4:53 pm
I just had a look - both seats are clipped down ok and the seals are in place. All carpet seems to have insulation - under the seats it is foam backed carpet, elsewhere it is felt - generally looks ok for its age - its obviously doing a reasonable job as the metal under it is really hot having just got back from a long run.
teenmal wrote:
Hi psquiddy,
Cheers..
Do you mean the plastic tray under the engine/gearbox? If so, yes it is fitted but I cant see anything that would be described as "sound deadening" - what should be there? Some form of heavy rubber mat?
Re: Soundproofing
Post by missfixit70 » Thu Jul 28, 2011 4:56 pm
There should be insulation under the metal of the engine covers that the seats are mounted on too & the plastic undertray under the engine should have a sort of insulated matting.
dunslair
Re: Soundproofing
Post by dunslair » Thu Jul 28, 2011 5:00 pm
missfixit70 wrote:There should be insulation under the metal of the engine covers too & the plastic undertray under the engine should have a sort of insulated matting.
Yep kind of like a dense foam but with a woven protective cover to it (like woven mail bags, not like Granny's knitting) :D
psquiddy
Re: Soundproofing
Post by psquiddy » Thu Jul 28, 2011 5:24 pm
There is insulation under the seat/engine covers, but not on the under engine tray.
Also - the foam backing under the chairs is broken , but complete - so when you fold the carpet the pieces move apart, but they seem to sit together ok when the carpet is folded back again - i guess that is not ideal, but it does not look as if I have got any real gaps
psquiddy
Re: Soundproofing
Post by psquiddy » Sun Jul 31, 2011 6:01 pm
I spent £5 on a carpet offcut and a couple of hours inserting a new layer under the existing carpets in the front floor, under the seats and the centre console - quite pleased as there is a noticeable noise difference.
i might try stuffing door and dashboard voids with some spare rockwool i have i the loft
Re: Soundproofing
Post by missfixit70 » Sun Jul 31, 2011 6:07 pm
I wouldn't use rockwool inside the front doors, not if you want the windows to keep working :wink: You can get self adhsive soundproofing type stuff, or I used self adhesive flashing from B&Q inside the doors & side panels.
munroman
Re: Soundproofing
Post by munroman » Sun Jul 31, 2011 6:11 pm
The Rockwool will also hold water, making a nice wet lump against any metal, so facilitating rusting.
Having it stuffed in the dashboard could well lead to fibres coming loose and spreading throughout the interior, itchy.
In summary, my advice would be, don't use it! :)
