Rev counter dancing all over the place
flyfisher
Post by flyfisher » Thu Jul 28, 2011 8:10 pm
Over last few weeks my bongo (2.4 diesel) rev counter has been going nut’s one minute its fine and then starts dancing all over the place and then will settle back down
Any one know what the cause is and any advice, is it something that should concern me ?
I ran this past Ian who had not heard of the fault before!
Thanks (new forum member but long term club member)
Re: Rev counter dancing all over the place
Post by missfixit70 » Thu Jul 28, 2011 8:16 pm
Welcome to the forum :D
I assume you mean 2.5l turbo diesel, there is no 2.4 :wink: Sounds like it could be the the sensor, thread here that should help - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=24171
flyfisher
Post by flyfisher » Thu Jul 28, 2011 8:28 pm
Yes that was quick and yes mean 2.5
Post by Northern Bongolow » Thu Jul 28, 2011 10:55 pm
could be worth checking the speedo correction chip,and that the alternator is doing what it should be too.
karena
Post by karena » Fri Jul 29, 2011 1:25 pm
defo check the alternator mine was doing that when my alternator went.also have you plugged amything new into the cigarette socket once put a cheap phone charger in and had similar effects.
flyfisher
Post by flyfisher » Fri Jul 29, 2011 3:05 pm
Thanks Guys
I have a cheapo phone charger will check if it only happens when plugged in like to look at simple options first :D
Post by missfixit70 » Fri Jul 29, 2011 3:10 pm
The alternator output should be somewhere between 13.8v - 14.6v, if it's less than that, it may be your issue, may be accompanied by sediment & charge light glowing, may not though :wink:
