Leisure Battery split charging kit
spad112
Post by spad112 » Wed Aug 10, 2011 8:45 pm
Hi fellow Bongoners
Does anyone know where I can get the diagram which shows how to connect up the wires from the leisure battery to the fusebox to power internal lights,radio etc.
Kit was bought off e-bay,but have lost the instructions of where to connect in the fusebox.
nigelgibson
Re: Leisure Battery split charging kit
Post by nigelgibson » Wed Aug 10, 2011 8:49 pm
if it was a Willinton kit give him a ring he's known to be really helpful. search his ebay user name [ willinton] for a contact number or email him. he regularly lists his split charge kits. if it's not i think there's a fact sheet in members area on how to change fuses 6,7,8 to lb if that helps.
Post by missfixit70 » Wed Aug 10, 2011 8:49 pm
If it's the Willinton kit, you remove fuses 1 & 8 (along with 6 & 7 if you've got powered blinds) & slide the small connectors in on thr bottom fuse connections to supply those circuits, having fed the wires through the bulkhead where the clutch cable blank would be.
waycar8
Post by waycar8 » Sun Aug 14, 2011 11:10 am
Hi I still had mine that he emailed so Ive forwarded them to your email address :wink:
