Tappets and compression
David Edwards
Post by David Edwards » Fri Aug 19, 2011 5:02 pm
Well folks need a bit of help,lol, anyone know what the tappet clearances are for the inlet and exhaust and what the compressions should be for each cylinder, any help would be greatly appreciated.
Re: Tappets and compression
Post by missfixit70 » Fri Aug 19, 2011 5:08 pm
Tappets - http://www.igmaynard.co.uk/bongo/forum/ ... it=tappets
From the manual
"Compression (kg/cmsquared - rpm)
Standard value - 30 - 200
Limit value - 27- 200
Variance limit between cylinders - 3kg/cm squared"
David Edwards
Post by David Edwards » Fri Aug 19, 2011 5:23 pm
awesome, thanks so much I really appreciate it as do the garage,lol.
Post by missfixit70 » Fri Aug 19, 2011 5:27 pm
Hope it gets it sorted [-o< , compression values are with a warmed up engine (but they should know that :wink: )
