dashboard battery chargingwarning light (V6)
Pablobongo
Post by Pablobongo » Mon Aug 29, 2011 11:14 am
Just come home from a short run to the gym, and noticed the battery charge warning light has come on. Had a quick look under the passy seat and the alternator is still there, with belt intact. Anything obvious i should be checking (fuse, relay) before i take her to a garage?........any help greatly appreciated.
Paul 2002 V6Image
Re: dashboard battery chargingwarning light (V6)
Post by haydn callow » Mon Aug 29, 2011 11:27 am
Put a voltmeter across your battery with the engine off......then do the same with the engine running.....it should read about 12volts and 14 volts respectivly.....if it reads the same for both then your alternator is not charging the battery...
If so...put the voltmeter to the biggest terminal on the alternator and earth....should read about 14.5/15 volts
Then report back with findings.
cheffy34
Post by cheffy34 » Mon Aug 29, 2011 3:06 pm
just out of a matter of interest has it got oil all over it :?:
Dar
Pablobongo
Post by Pablobongo » Mon Aug 29, 2011 8:16 pm
No Dar, it hasn't (i take it you mean the alternator) why do you ask mate?
Paul 2002 V6Image
Pablobongo
Post by Pablobongo » Tue Aug 30, 2011 4:10 pm
Well, the diagnosis is, non-functioning alternato :( r.........currently residing at a local auto electricians, who are going to remove and re-condition it, and re-fit it and warranty it for 12 months.....all for the sum of £160.00 sterling, didnt think that sounded too bad, as my breif research into a replacement looked like around £180 for a different "exchange" re-conditioned one type deal plus the cost of removal and refitting. :?:
Your thoughts please.
Paul 2002 V6Image
cheffy34
Post by cheffy34 » Thu Sep 01, 2011 3:50 pm
PM sent pablo
Pablobongo
Post by Pablobongo » Thu Sep 01, 2011 6:43 pm
Paul 2002 V6Image
