What's Wrong With This Picture?
Post by Ian » Mon Aug 29, 2011 12:37 pm
Thanks to Ady (Northern Bongolow) for all his help over the weekend =D> . He spotted a problem straight away that still needs to be resolved. So now let's see how good you lot are.......I wonder if any of you engine experts can spot what is wrong with this photo?
bongoing-mad-simon
Re: What's Wrong With This Picture?
Post by bongoing-mad-simon » Mon Aug 29, 2011 12:49 pm
hi ian , no manifold heat shield???? not that i know anything about engines LOL just mines got one and this one hasn't .....
Simon
I'm Bongoing mad R U?
Post by missfixit70 » Mon Aug 29, 2011 12:50 pm
Keep guessing :wink:
longhaul8
Post by longhaul8 » Mon Aug 29, 2011 12:56 pm
It shows a round yellow loop on top of the dipstick that is a very rare site on a bongo...............lol
munroman
Post by munroman » Mon Aug 29, 2011 1:05 pm
Lots of soot above the exhaust manifold between cylinders 1 and 2?
Post by Ian » Mon Aug 29, 2011 1:46 pm
bongoing-mad-simon wrote:hi ian , no manifold heat shield???? not that i know anything about engines LOL just mines got one and this one hasn't .....
Not the right answer! However, the heat shield disintegrated when removed, and I need to find a new one quick before Marianne's big end gets any hotter........... :lol:
Any other guesses?
mcdonaa
Post by mcdonaa » Mon Aug 29, 2011 1:59 pm
No jubilee style clip on the intake pipe?
dave_aber
Post by dave_aber » Mon Aug 29, 2011 2:02 pm
That manifold is different to mine - the take-off at the back, which looks like a blanked EGR take-off is a flanged joint. On mine (1997) the EGR outlet is a big pipe with a threaded fitting, like a big plumbing fitting.
Is it a Bongo manifold?
Image...Image
widdowson2008
Post by widdowson2008 » Mon Aug 29, 2011 2:28 pm
What's this? I aint got one. :( (is that a good thing Ady?)
Is this what you're looking at Dave?
Steve
dave_aber
Post by dave_aber » Mon Aug 29, 2011 2:30 pm
Yup, that's the bit I'm on about.
Is it possibly a ranger manifold?
Image...Image
widdowson2008
Post by widdowson2008 » Mon Aug 29, 2011 2:34 pm
........and it's had a head change? always a dodgy sign.That's an AMC head.
........and it's scruffy
........and half the protector on the big plastic tube is missing
........and if Ady says it has a problem
........and the pic aint in focus :wink:
Sell it for spares Ian I'll give you a fiver for the dipstick - cash - today :lol:
Steve
Post by Ian » Mon Aug 29, 2011 2:59 pm
dave_aber wrote:That manifold is different to mine - the take-off at the back, which looks like a blanked EGR take-off is a flanged joint. On mine (1997) the EGR outlet is a big pipe with a threaded fitting, like a big plumbing fitting.
Yes, well done Dave, you win. =D> Send a stamped addressed envelope and I will send you a fridge magnet....
It is indeed a non-Bongo manifold, but it seems to work OK, and gets REALLY hot (as Marianne will attest). The problem is, whoever fitted it, it has ended up very close to the large intake hose, which has melted! So i'm trying to track down a (flat) manifold which has the EGR pipe, and then get a new inlet hose fitted, all by the time I drive down to Looe.
And well spotted Steve, it is an AMC head, but no problems experienced with that either.
Post by Simon Jones » Mon Aug 29, 2011 8:37 pm
Ian wrote: So i'm trying to track down a (flat) manifold which has the EGR pipe, and then get a new inlet hose fitted, all by the time I drive down to Looe.
I think I have all the bits you need. Will drop you an email.
Post by Northern Bongolow » Tue Aug 30, 2011 2:14 am
the manifold and possibly the turbo is off a wle7 which has the egr flange on the wrong side,however this has been blanked off but is a large lump of cast that is too near the rear air pipe,it has melted the plastic pipe and sucked the heat shield foil into the pipe,it didnt block the pipe but ended up a melted blob of the 2 mixed with a large hole for the air to be allowed in bypassing the airfilter etc.
the picture shows the get you home bodge done to the pipe to get ian home, but is only a temp job.
thanks to simon for the offer of help supplying the parts ian needs.
bikerbob
Post by bikerbob » Tue Aug 30, 2011 6:50 am
Apologies for butting in, my 97/98 2.5td bongo is in need of a new manifold shield, where can they be obtained from.
