cruise control
MAD DOG MURRAY
cruise control
i'm thinking of fitting cruise control to my bongo,have been told its not to hard to fit,is this true and any hint and tip would be great.thanks
pippin
- Peg leg Pete
Dave up north
I wouldnt buy another car that hasnt got cruise.
It improves economy, as you are not inadvertently slowing down and having to accelerate to maintain a speed (trust me. Set cruise to 75 and see all the cars overtake then slowly back off to 65, then back up to 80)
It saves breaking the speed limits, especially in town and through roadworks
It makes for a stress free journey.
Cruise plus Satnav makes big Dave a happy guy.
P.S. Erin doesnt like using the cruise control. Hence the 3 points on her licence.
Dave up north
MAD DOG MURRAY
foot dies
as i spend alot of time over the pond, at times driving 1000miles in one day,mainly using toll roads.trying to keep to the same speed kills my right foot,so cruise could be worth it,yes or no.
but has anybody fitted it to there bongo??????
- Simon Jones
I'm part way thru fitting a unit from Waeco & have one issue to solve. The actuator needs to be connected to the vacuum system & I have yet to confirm exactly which pipe to cut! It looks like there is a pump which does the power steering & I beleive the same unit feeds the brake servo. Hopefully, I will find this info out at the Bash & will be able to complete the project.
Bumbly1
SimonSimon Jones wrote:I'm part way thru fitting a unit from Waeco & have one issue to solve. The actuator needs to be connected to the vacuum system & I have yet to confirm exactly which pipe to cut! It looks like there is a pump which does the power steering & I beleive the same unit feeds the brake servo. Hopefully, I will find this info out at the Bash & will be able to complete the project.
Is there a chance you can put together a factsheet when you complete it?I am interested in fitting one too as are some others.
Tom
AliBongo
I fitted an Audiovox cruise control to our Bongo a couple of years ago and couldn't live without it! It was pretty easy to fit, I put the actuator under the passenger seat fixed to the chassis rail and I don't remember having to cut any pipes to hook into the vacuum. I am offshore Norway at the moment so I can't check what I did for the vaccum but I remember it being very easy. For the speed sensor I tried to use the vehicle speed wire which every vehicle is fitted with these days but it wouldn't hold a steady speed. Perhaps I got the wrong wire but I ended up fitting a magnet/sensor combination which also came with the kit. You glue a magnet to the propshaft and mount a sensor nearby, there was a convenient bolt on the gearbox. The control is very small, about 4 x 3 centimetres with four buttons and I mounted it on the dash to the right of the steering wheel where there was a small coin holder. I got the kit in the USA for about $90 and it comes with an amazing variety of fittings for just about every situation. I had it on my last 4 cylinder petrol car using the coil as the speed sensor and it worked great except I had to tell the unit it was fitted to a 6 cylinder vehicle to get it to hold speeds over 70mph! If you do a Google search on Audiovox cruise control you will get lots of hits and I can put together a help sheet if anyone wants one.
Stuart
Stuart
AliBongo
pippin
brianwfl
Hi peeps,
ref cruise control, i have had one fitted by howard mays ltd (only done by howard mays as i am aircrew and didnt have the time prior to going to north norfolk on leave0. it s resonably simple to fit as a diy project. if you can fit a radio ect its a doddle. if you are wary of wiggle amps and things akin to that Steve Jones of howard mays can fit at your premises.
cost control module/operating stalk/wiring ect £295, for manual trnsmission £15 for clutch switch, fitting if required £120
I tow a caravan or my sons' go kart trailer find it very useful on long journeys. have not had it long enough to fully assess fuel economy but it does save fuel for the reasons previously stated. it is very useful for ensuring that we are not captured by mr plod with his magical lantern
brgds to all
brianwfl
brgds to all
brianwfl
Dago & Mrs D
- Simon Jones
Tom, yes I intend to put together a fact sheet when I get it in & working.
Pippin, you are correct, I posted a question on the forum a while back regarding best place to get a vacuum take off, but it veared off-topic & I never got an answer. Perhaps someone with engine manual cd could have a look for me, please?
Pete
