It was either replaced in Japan or is the original as it's covered in Japanese writing
Original Jap Battery
dandemann8
How long is your SB supposed to last, we've had our Bongo just over three years now and having just returned home from a very nice long weekend away I've had to put it on charge for the last 24 hrs as it was only showing 10.6v on my meter:?:
I've never had an issue with starting so just curious for now finger's crossed
Bongo no more........... ;-(
BongoMTBer
Re: Original Jap Battery
I am amazed it started with a standing voltage of 10.6v Your sure your meter is well?
dandemann8
Ooooop's I meant 11.6v, should of read my initial post
- bongodonkey
- Tribal Elder
Erm we've had Mr Miagge for just about a year now and it came with it's original battery - still got and it and it's going strong.
Can't say how long it will last - the only suggestion is to find a battery expert with no vested interest in selling you a replacement!
Oz, Sam & the girls | 2001 V6 AFT | LPG | 321Away F/S/C | A Bongo called OLIVE
dandemann8 wrote:Ooooop's I meant 11.6v, should of read my initial post
11.6v is quite normal if you are starting the vehicle with the glow plugs activated.
Cheers..
dandemann8
I hope it ain't got glow plugs its a V6teenmal wrote:dandemann8 wrote:Ooooop's I meant 11.6v, should of read my initial post
Cheers..
maxi_77
If the 11.6 was the standing voltage with nothing on then that is flat, flat, flat. Very close to zero percent capacity. Unless you have a smart charger with around 10 amp output you will need at least 48 hours charge to get it back to it's best.
White diesel Bongo
- mikexgough
Duncan, I take it the battery has markings like or similar too - 75D26L on it somewhere?
That is the Japanese JIS number kind of like the 068/249 DIN number the EU use.
I was told many years back that most car batteries had a useful life of around 6 yrs with every day use, not sure if that still stands, i assume you've checked the electrolite levels if possible, i also assume sealed batteries must have a vent on them so could also loose fluid through evaporation.
someone with more knowledge than myself will be along soon
Got a Bongo for the Wife, Best trade-in ever
