thanks
Jezza
Nope it means one colour on the top half & another on the bottom half, the clue is in the facvt it says "two tone" at the top of the table of colours, eg mine isJezza wrote:I think the codes that are colour 'x' over colour 'y' means it's one of those pearlescent paints that require a metallic base coat under the main colour. On the Paint factsheet 14D is quoted as Greece Green - not over anything - so it's not one of these pearlescent colours which has a silver base colour, so I assume that means it's a "solid" colour (can be painted in 1 shot!)
If yours is a standard colour it'll either be silent silver or highlight silver. Not sure re the paintcode on yours, it's usually in the one paint code as per the factsheet.What I actually want is the code for the silver that the lower part of the van, and bumpers, are painted !
I had a look at the tag on the passenger side where I found the 14D in the body colour box - but where does it tell you the secondary colour (i.e. the silver?)
francophile1947 wrote:Greece green is usually over Highlight Silver.
Not quite Kirsty, both are basecoats that require a clearcoat on top. Some modern mica/pearl/xyrillic require a coloured groundcoat firstmissfixit70 wrote:Nope it means one colour on the top half & another on the bottom half, the clue is in the facvt it says "two tone" at the top of the table of colours, eg mine isJezza wrote:I think the codes that are colour 'x' over colour 'y' means it's one of those pearlescent paints that require a metallic base coat under the main colour. On the Paint factsheet 14D is quoted as Greece Green - not over anything - so it's not one of these pearlescent colours which has a silver base colour, so I assume that means it's a "solid" colour (can be painted in 1 shot!)
14E - 5S + 4Z - Neat Green over Silent Silver, which means it is green on the top half & silver on the bottom half, both of which can be "painted in 1 shot"
missfixit70 wrote:Yeah, but not a green coat over a silver coat to give the required finish as the OP was saying, the colour itself is one colour on top a normal primer isn't it?
Jezza wrote:Ok - this is getting confusing!
The fact sheet regarding paint colours states 14D is Greece Green - there is no reference to it being over anything - so I'm taking it that Greece Green is a "solid" colour - not requiring a metallic base coat (Highlight Silver or Silent Silver)
You are right kirsty but they ARE basecoats, meaning they require a clearcoat on top. You can't get a shiny metallic finish straight out of the tinmissfixit70 wrote:Jezza wrote:Ok - this is getting confusing!
There is no metallic base coat, as I said above Silent Silver & Highlight Silver are the paint codes for the lower half of the body (ie "neat green over silent silver" is neat green on the top half - silent siver on the bottom half - not a base coat, they are both metallic type paints in their own right), NOT for a metallic base coat, the base coat is just a bog standard grey primer for both, you are confusing yourself
