Can anyone save me time rooting around under the dash by pointing me in the direction of a good point for earthing an accessory?
Ta
Good earth, driver's side
'Enjoy every sandwich'
Re: Good earth, driver's side
Your right knee position under the dash,there should be an earth bracket with a designated bolt(set screw)
Hmm, just had a squint with the fuse cover and under-steering plastic panel removed, and can't see it. Is it behind the fuses?
Ah yes, think I've got it. The screw was rather hidden by the alarm system box that's been crammed in there.
- daveblueozzie
By your left leg drivers side centre console small panel at bottom, two good earth points using the bolts.
Lost without my Bongo.
M 80NGO
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Under the centre console there are a couple easy peasy lemon squeezy, thats where i earthed my LED green footwells
