Top water hose
Gary Appleby
Top water hose
Hello all you techy types
The top water hose has gone on my bongo, Going home from work (after a 12 hour night shift) I heard a pop from directly under me, saw a puff of smoke and some water leakage, pulled over the the hard shoulder, turned off engine and promptly awaited the arrival of the rescue people.
My question is, did I turn the engine off quick enough and is it easy to replace this pipe, I found the exact one i need on bongobits.
GJA
PS Click link below for image
http://www.9xdead.com/tophose.jpg
GJA
- Peg leg Pete
Seeker
- Peg leg Pete
Bongo-Shaftsbury
Mine went recently. Takes about three quarters of an hour to sort.
A set of locking pliers are handy for the spring-loaded pipe clips. You'll need to remove the plastic tray under the van too for better access to the bottom end of the pipe. I'd also recomend having the van on ramps at the front - gives you more access under there and apparently helps when you refill the system.
Remember to open the bleed pipe under the passsenger seat when you refill and keep checking the level for the next few days until it sorts itself out. Mine needed an extra litre after a couple of days.
- Peg leg Pete
Gary Appleby
Gary Appleby
Right it was definitely a 2 man job, 1 to hold the tube and clip in place (at the right angle) the other on the floor tightening up the screw on the jubilee.
Currently experiencing wierd and wonderful water works, first time went out for a run down hill fine, up hill temp gauge went to the max, fan kicked in and settled, got back checked water level, only a small amount gone.
Topped up, left engine running for 15 minutes every now and again put foot on the accelator far a while, fan kicks in temp gauge does not move, looking good, will update later.
Temp gauge still not moving, but still loosing a small amount of water ! got Caerphilly mountain to go up soon !!!
GJA
GJA
andy caff
my top hose arrived today, flushed system and fitted, cant take her for a run, while she was on the ramps i noticed CV boot split, tried universal kit (not so universal). Had to order one from bongo bits, yet to fit.I've run her on tick over till she warmed up, front and rear heaters working fine hope this ia a good sign cos two weeks in st austell commin upand dont want to arrive on back of low loader
- Peg leg Pete
andy caff
- Peg leg Pete
- Peg leg Pete
Pete
