clean that engine
horus01
- Bongonaut
clean that engine
Recently my V6 suffered an oil leak from the crank seal.As a result oil all over the underside of the engine-any recommendations for cleaning agents to remove the unwanted oil.I'm afraid of using anything too strong that might cause damage to any other seals or hoses.Also afraid of what damage a jet wash would do due to the position of the engine under the seats and handbrake/gearstick etc.
al & chris
- Tribal Elder
Re: clean that engine
I have always used jizer brushing on and stippling in with a brush. then rinsing off with a hose . Allso spray it on for larger areas.
horus01
- Bongonaut
many thanx for that-have odered some from ebay to trial
al & chris
- Tribal Elder
Just remember to keep it away from any waxoiled areas. particularly if spraying as it will remove waxoil also.
It also dissolves tarmac very readily, so take care if it's parked in the road or a tarmaced driveway.
Frank
Frank
They flew, I took up naturism
M 80NGO
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
5 ltrs of brake and clutch cleaner a spray bottle and some cardboard to lay under the van, fill up the spray bottle with B & C Cleaner then starting at the top spray the engine and watch the muck n oil run off and evaporate
easy peasy lemon squeezy
- dandywarhol
.................and keep it away from the cambelt!
or just leave it..dirty...its an engine
