inner rear wheel arches
karen
Post by karen » Sun Mar 04, 2012 5:44 pm
been advised that i should treat the inners
it has a rear conversion in it just now so i will need to work out the removal of this first.
once this is off how are the panels held on ?
afraid i cant see much until conversion is out - i assume its more or less clips same as the door panels? and there is a screw cubby hole in the middle
then i assume it's just waxoil squirted down inside?
MountainGoat
Re: inner rear wheel arches
Post by MountainGoat » Sun Mar 04, 2012 5:54 pm
Depending on the type of conversion that you have it should be possible to inject waxoil via the gas bottle cupboard and via the rear light cluster once removed. The problem is that you are working a bit blind can't see well enough to see if there is any rust that needs treating before injecting the waxoil.
Tony
Post by Northern Bongolow » Mon Mar 05, 2012 12:21 am
and however or when ever you do it dont forget to pull all the seat belts out to the full extent or you will get them covered in the waxoil while on the cassette #-o #-o #-o
winchman
Post by winchman » Mon Mar 05, 2012 7:13 am
Northern Bongolow wrote:and however or when ever you do it dont forget to pull all the seat belts out to the full extent or you will get them covered in the waxoil while on the cassette #-o #-o #-o
Now thats a useful tip :D
briwy
Post by briwy » Mon Mar 05, 2012 10:17 am
And warm the Waxoyl up before you use it to make it thinner so that it will get into all the joints better .
karen
Post by karen » Wed Mar 07, 2012 10:11 pm
i've got the first side of conversion out and removed all the bits so i can get nice easy access
will hopefully do at the weekend - hopoefully nice weather
good tip for the seat belt - obvious but wouldnt have thought about it till too late
