inner rear wheel arches
Posted: Sun Mar 04, 2012 5:44 pm
been advised that i should treat the inners
it has a rear conversion in it just now so i will need to work out the removal of this first.
once this is off how are the panels held on ?
afraid i cant see much until conversion is out - i assume its more or less clips same as the door panels? and there is a screw cubby hole in the middle
then i assume it's just waxoil squirted down inside?
