Hi All you V6's
I have oil leaking/seeping from the near-side cam cover (rocker cover). I think the breather system is blocked on that side.
Any way I want to take the cover off and check it out. Repair any faults and replace the cover and probably do both sides while I'm at it. So I shall get a set of seals and I need to replace the sealing washers as they are all in a poor state.
BUT is there any thing in particular I need to watch out for while I do this or any other parts that I should be prepared to change while I'm in there?
Looking forward to your advice
regards Grahame
V6 cam cover removal / re-fit
Grahame at work
Joanie2 has had a sex change and is remaned Bert
Grahame at work
Re: V6 cam cover removal / re-fit
no one?
Have I asked a wrong or stupid question?
Or am I heading into virgin territory?
If so then I’ll record everything and let you know how I get on.
regards Grahame
Ok,just to keep you happy at work,check the mating surface on the rocker cover/s.Make sure its/they are not warped.
