Hi I'm new to the forum and very new to Bongo's,
Ive had my 96 2.5 diesel a week and when I try and start it in a morning or when cold, all that happens is the starter motor just clicks with no engine turn over.
After a while of turning the key it then try's to start but then its very groggy until warmed through a little.
Any help would be gratefully appreciated.
Not starting when cold :(
Re: Not starting when cold :(
Flat battery/dying starter solenoid/duff glow plugs
Julian
Julian
yep
http://www.ebay.co.uk/itm/MAZDA-BONGO-2 ... 43af077bb7
fits most starters on normal diesel
winter ones with 2 batteriescan have a different one
Buzza
Thanks so much, Its definitely not glow plugs or battery. So pretty confident it will be the starter solenoid.
Really appreciate the link to ebay, Ive purchased the kit so now to find the best way to get to the starter motor
Buzza wrote:Thanks so much, Its definitely not glow plugs or battery. So pretty confident it will be the starter solenoid.
Here you go.......
http://www.youtube.com/watch?v=5pnySma88gY
from memory, lift drivers seat, remove battery connections at the battery first, then remove connections at the starter(low down to the rear of the engine.}
remove 3 bolts, sorted.
clean up the connections when refitting.
be carefull not to break the wires to the fan switch,or pull on the wiring loom too much.
beaten by teenmal, pics are better
Buzza
hahahaha on the video @ if you cant disconnect the battery, Close the bonnet and take it to the garage.
Thanks for all your help, I'm sure when the bits get here it'll be a walk in the park
Buzza
Well the parts came today and it was sorted in under a hour, A job made easy and very enjoyable thanks to you guys, Cheers
