Mason alarm query
sunnyjim82
Mason alarm query
Post by sunnyjim82 » Sun May 20, 2012 12:08 pm
Fitted a mason alarm over the weekend,I expected a rise in temperature reading after reading a few threads on the matter however mines only moved slightly!it was at the 11 o clock before and now half way between that and 12 o clock. I also had to move the alarm setting from 4 to just below(approx 3.8) which seems to be right for the normal running temp. Is this normal? Or is my coolant system top notch!?
Noticed a difference when I had 8 men in it going up a hill!the temp rose a little bit and the alarm went off briefly but that's about it!
sunnyjim82
Re: Mason alarm query
Post by sunnyjim82 » Sun May 20, 2012 12:09 pm
Don't know why the little face came up with shades on but that was supposed to read '3.8'
Post by g8dhe » Sun May 20, 2012 12:51 pm
You should find the gauge is more "active" rather than just sitting at the 11 O'clock position, it should be moving up/down with load - which sounds like it is!
The 3.8 was because you put the a ")" after it, so it looked like a Smiley code - 8) - which is "8)" just leave a space before the end bracket 3.8 )
sunnyjim82
Post by sunnyjim82 » Sun May 20, 2012 1:14 pm
Oh right! 8) yer it is much more responsive it's great ,really happy with it! Just wondered if it was normal for the temp to be so low after reading everyone else's at 1-2 o clock
daveblueozzie
Post by daveblueozzie » Sun May 20, 2012 2:49 pm
Mine sits just under the 12 o'clock position, the gauge moves a bit if i put my foot down on the hills , mine is set to about number 4 on the dial.
The position on the gauge is lower than it used to be (about 1 o'clock), but i did a coolant change and used an original Mazda stat and a fitted a new water pump.
Lost without my Bongo.
