Noticed my track rod ends also have splits,is it worth changing the rubbers or the whole lot? there is not much in it price wise..
take it the tracking will have to be re done if just rubbers are changed?
track rod end, new rubbers or change the lot?
- helen&tony
Re: track rod end, new rubbers or change the lot?
For the cost of track rod ends , it's cheap enough to replace them
You might as well change the whole lot. There's only about £3 difference between the cost of the bush and the cost of the unit. That's because the full units are after market copies, but the bushes are genuine Mazda items, see the "Steering & Suspension" section in the club shop.
while you're at it, change the steering gaiters as well, nothing worse that getting all your steering set up again, then having to pull it all to bits when you notice you gaiters splitting?
why not do your torsion bar rubbers while its up in the air also. then all should be nice and tight
Got a Bongo for the Wife, Best trade-in ever
