Monitoring the Leisure Battery
spud350
Post by spud350 » Tue May 22, 2012 7:25 pm
Anyone got one of these? http://www.ebay.co.uk/itm/50V-200A-BLUE ... 19d08ad8dc
Willinton kit on the way and as much as I can't be bothered messing with wires this seems ideal to keep an eye on the battery. What says you?
dave_aber
Re: Monitoring the Leisure Battery
Post by dave_aber » Tue May 22, 2012 8:00 pm
Aye, I've got one, in green though.
I have it wired through an ON-OFF-ON switch so it can monitor either battery. Fits in a 3-way switch block in the dash binnacle.
Image...Image
spud350
Post by spud350 » Tue May 22, 2012 9:03 pm
Hey Dave got any pics? Also do you have a link to the switch block?
Cheers Spud.
dave_aber
Post by dave_aber » Tue May 22, 2012 9:10 pm
I don't think I have any pics of that side of the dash, I'll have a sniff around.
I got the on-off-on version of this, but they don't seem to do it on that website any more.
Edit : Here's one
Edit 2 : Image
Here's the meter in-situ. The switch is underneath it, on the underside of the binnacle, Rock left for L/B, right for S/B, centre for off.
Image...Image
spud350
Post by spud350 » Tue May 22, 2012 9:35 pm
Did you cut your plastic to fit that in?
Post by g8dhe » Tue May 22, 2012 9:51 pm
Do note that they don't supply the shunt resistor for measuring the current however!
MPORTANT : A 200A 75mV Shunt (not included, available in our store) must be added if the meter is used to measure current / amps; otherwise the meter will be damaged.
you need to buy that as a separate item - another £8
spud350
Post by spud350 » Tue May 22, 2012 10:11 pm
Yeah a bit sneaky but did notice that. Still not bad to see what the battery is doing though.
321Away
Post by 321Away » Wed May 23, 2012 9:07 am
http://www.ebay.co.uk/itm/NEW-Mini-12V- ... 4ab63d80a7
sure you can get em cheaper from HK, but quick n easy
Julian
dave_aber
Post by dave_aber » Wed May 23, 2012 9:23 am
spud350 wrote:Did you cut your plastic to fit that in?
TBH, I can't remember 100% - I think the 3 switch holes have dividers between then, which need to be cut away, but I don't think I made the hole any bigger.
The meter itself is just held in with hot glue. I didn't intend to use it as an ammeter, just wired across the batteries as a voltmeter.
Image...Image
gasace
Post by gasace » Wed May 23, 2012 6:20 pm
I have one fitted in the"zig" type unit, I wired it up through a double throw switch so I can check both batteries a the same time. My radio, door lock and rear cabin main light work from the car battery, so I wanted to be able to check them both. I have a battery charger connected to the circuits so I can charge either battery from the electric hook up, if available. If no hook up I go for a drive when needed.
Dodgey
Post by Dodgey » Thu May 24, 2012 9:49 am
That's the way I wired one into my friend's Bongo - a three way toggle switch (known as SPDT or 1P2T switches - Single Pole, Dual Terminal) - so you can have leisure battery, starter battery, and off in the middle. I'll knock up a basic wiring diagram if I get a chance today. I mounted his display and switch in a plastic wall box normally used to blank household mains sockets and screwed it to the side of his kitchen unit.
