Right having replaced pretty well anything and everything on the cooling system [ including cylinder head] of our early model 2.5WLT Auto it now appears to be running like a dream on the engine front.
Now down to other stuff.
I notice that the auto box appears to lag shifting into the higher gears. This is most prevalent at slow road speeds. I find that if the revs are high it will take ages to shift. If I come off the throttle then it appears to shift.
Please note that I am not "kicking down" at this time.
Any fixes for this as I am sure that it impacts on the thirst of the beast?
Sluggish Gear Change
- Driver+Passengers
Re: Sluggish Gear Change
Have a search for throttle position sensor (TPS). It's under the driver's seat and you can rotate it a few degrees to alleviate this problem.
Ok...will check out the TPS....thanks for that.
- Driver+Passengers
Worth checking your ATF level too - dipstick is under the driver's seat also.
Procedure for checking level should be in here somewhere... viewtopic.php?f=43&t=54458
