Engine cradle
Engine cradle
The cradle holding the engine has a big 3" diameter metal tube, welded to brackets in the bay under the front seats. The bracket and connection is getting quite rusty on mine. Is this common and is it problem?
- Mickymouse
Re: Engine cradle
Mine was a bit rusty on the nearside,I cleaned it off with a wire brush and treated with Kurust and then painted with a black gloss metal paint,it still looks like new two years later!
White 1996 P.reg SGL3 2.5D AFT Side Conversion
Re: Engine cradle
it seems to be a problem, and only much on the passenger side for some reason? maybe cos the turbo gets hot?
Julian
Julian
- Simon Jones
Re: Engine cradle
If you feel the need to change it, I have a spare one available.
Re: Engine cradle
Yep, only on the pass. side.
I'll give it a wire brush and maybe under seal it.
Re: Engine cradle
All done. Rust removed, which was fairly superficial. Kurust applied, and tomorrow I'll under seal the lot.
Thanks !
Thanks !
