Electrical connection IDENTIFICATION
Just found an electric connection under the drivers seat.Any ideas?
- Simon Jones
Re: Electrical connection IDENTIFICATION
There is a pressure switch in the seat so that the seatbelt light comes on when you sit on it without the belt on. Nothing bad will happen if this is not connected. Typically this will get disconnected if the seat is removed (usually to get better access to work on the engine).
Simon Jones wrote:There is a pressure switch in the seat so that the seatbelt light comes on when you sit on it without the belt on. Nothing bad will happen if this is not connected. Typically this will get disconnected if the seat is removed (usually to get better access to work on the engine).
Bugger!! No ejection seat then> Thanks
