Hi Guys,
Have cleaned the high lift roof, but the gel coat on the fibre glass is dull. Any one know of a good product that will put a shine on it?
High lift Roof clean/Polish.
windywatson
- Tribal Elder
Windy-Watson
2001 V6 Tin Top
2001 V6 Tin Top
Re: High lift Roof clean/Polish.
i used to work in the fibreglass industry if it is very dull then a product called g6 or g7 made by Farecla best to use a electric buffing machine with a sponge head , it is very important to wet the head first and use a slow speed or you will burn the gelcoat by wetting the head will also dilute the rubbing compound but this will help lubricate, when happy with the results or if only slightly dull then use t-cut followed by a good quality wax if you know any friendly boatbuilders then try and nab some mirrorglaze wax hard work to put on and polish but well worth the effort
one last thing you might need to tape up your stickers
very messy job to do, but great results
