I wonder if anyone can help diagnose a problem I have, or maybe I should say, an issue that I'm worried might become a problem with my 2.5 diesel?
In a nutshell, when I turn the key, wait for the glow plug lights to go off and go to start the engine, nothing happens. If I then turn the key back and instantly to to start the engine again, it's fine.
This is happening about 1 out of 5 or 6 times. At other times it's fine.
It started to happen almost immediately after I had a few issues with my leisure battery (a fuse went so I had to repatch everything back to the starter battery until I replaced the fuse) so I initially put it down to a battery issue but I think the battery's okay.
Does anyone have any thoughts? Starter motor?
Many thanks in anticipation
Christopher
Intermittent starting problem
Re: Intermittent starting problem
assuming its the regular diesel
i would start with
http://www.ebay.co.uk/itm/MAZDA-BONGO-2 ... 43b0d9e8e4
you will find the one on the positive side might be no thicker than a fag paper
i would start with
Goodfella211
I had this problem and forked out for a new starter motor. Turned out that the gear stick was not engaging into park properly. Next time it happens just move it in and out of park and then try it again.Nogob wrote:Hi
Christopher
M 80NGO
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Also check that all battery terminals are clean and tight and the battery earth is clean and securly fitted to the vans chassis.
Keep us posted, Pete.
Hi, thanks to all for the advice. It hasn't actually happened again since I posted the original message!
