I topped up the coolant with some water and drove it another 50 miles and then checked the level, level had stayed the same. Drove home and then checked the coolant level, it had dropped, but not by much.
Watched the You Tube vids of how to bleed a bongo several times over the weekend and learned a lot. First thing I did was start the Bongo and get it up to temp and check the bottom hose, STONE COLD
So, now I plan on trying to do the you tube bleed thingy with a mechanic friend of mine and a few others that I can get a hold of from BF, all you East Lothian members
I have a few questions:
My Bongo is also LPG but is disconnected due to the engine being replaced, I'm due to have that fitted next week before the coolant bleed. Should I do the bleed first?
I drove the Bongo back from Bury to Edinburgh with air in the system, will I have done any damage?
Should I drive it now?
Any other info would be great, I'm just about Bongoed out
